wexy21
You're Boosted!
On my way to work today my trans started slipping in 3rd and 4th. The only way I could get it to catch was to hit the gas and get it to downshift. It would catch only to slip again right away. At a stop I could manually shift 1st and 2nd but when going into drive it would slip around 40mph. I was able to get up to 60 but not for long.
I guess my trans is toast and will only get worse?
Is there anything I can check or look for before I park this and start taking it apart?
What transmissions could I look for at a junkyard or for sale that would be an easy swap?
Could it just be my torque converter? The trans doesn't leak and the oil looks good, also, the temp gauge I installed shows that it's in normal temp range.
I can take the trans out myself, but have never done that before. If I need it rebuilt, I figured to look for one already complete in my area.
