I was told this is the way to go. The problem is when I was on WOT before I had the tranny rebuilt. It wanted to do a kickdown when I was on Topgear. As you might realize. That is not a good thing..
I was told this was the way to go. So that's why I did it.
It feels like it goes into neutral or like it shifts down. It revs up alot and it does not sound nice, sounds like you hit the clutch with a manual transmission. As far as I can see it happends in every gear, I havent really tried it that hard. Can not be good for the tranny doing this.
When I do a kickdown it feels like it is slipping like you explain..
5500RPM governor was also what I was told to do. 4200 is not the way to go for me at the moment. I'm not 100% sure that it is an 5500rpm governor. Could be 5000rpm also. I'm not really sure.
I do have the multidisc converter. Same as above. I was told to use this, this is supposed to be the best of the best 8) .
I know how to adjust the TV-Cable. I'm not sure if I need to adjust it down by the tranny. Could the cable itself be working poorly? Is it necessary to replace it? I've followed the instructions to which you describe, I have a Syclone overhaul video and they describe it quite nice how-to adjust the cable. So that should be accurate.
I really appreciate your response, and hopefully you understand my english and my expressions. I have just followed advice from people who have helped me way back with my truck.
Best regards // Markus
Blake said:
Why didn't you want it to be able to do a forced downshift? I assume your talking about the the B&M valve that eliminates it. Your gonna lose a lot of "pulling" power when you want to accelerate. I'd change it back to the way it was.
When you say "it drops out of gear" do you mean it feels like it went into neutral? Does it matter what gear you are in?
If you are in 4th and it does it, it's because of excessive band clearance. Since you've eliminated the ability for it to downshift, instead of releasing the 2-4 band and shifting down to third, the band is just slipping.
Why did you go with a 5500rpm governor?
What kind of buildup do you have?
People used to be really bad for raising the governor but the stock cam doesn't make any power past 4600~4800 rpm.
The Vigilant is a really good converter. Long as you got the single disc(multi disc styles create false knock and cause a lot of problems). They sound like a coffee can full of marbles when the clutches aren't engaged.
PS:
Don't play with your TV cable to correct this. You will burn up your transmission. Set it back to the original setting(push the button, shove the plunger in, rotate to WOT and let it ratchet out). Let us know if you need help doing that.
