Transmission issue? But not sure
2500avalanche
Well-known member
So I took my truck out tonight, and ran into an issue. Truck accelerates fine and goes through the paces, but around 75mph I am getting a vibration (pulsation) that gets pretty bad the faster I go. Also, when I am at 60 mph and I hit the gas, boost shoots up to 16lb, rpms go up, but the truck does not accelerate.
When I go home I check the tranny fluid and it is all there and still red. WOndering if it could be the convertor or tranny?
Things I am going to try:
1: Remove prop shaft to see if vibration is still there
1A: If so, I am guess tires are next (Tires have a lot of tread but are about 8 years old)
2: Change tranny filter to see if that fixes the issue
2500avalanche
Well-known member
So an update:
Went out today.
Went through each gear, and it worked.
Went to D, and that worked
Went to OD and that worked, went through all gears.
Tend to believe it IS NOT the tranny, what could it be?
2500avalanche
Well-known member
I think that is what I am leaning too. I have had issues with it in the past. I might look at buying a replacement from sportsmachines
Sy 0145
I have heard of people having problems with that one from sport machines. Maybe one for a 91 S10 with a 4.3 and automatic would work.
2500avalanche
Well-known member
Good to know. I will look into them. I know I have had issues with the one on it. every once in a while it seems to go loose
Poconojoe
The part numbers for the TPI TV cables are 25521263 (85-88) & 10163879 (89-92), IIRC the newer cable is slightly longer then the older one.
