ShuggsRR
What direction does the fluid flow?
Trans -> Factory Rad Cooler (top port) -> Factory Rad Cooler (bottom port)-> transmission
is this correct?
Im installing a new trans cooler and want to know which side I should install it on...
Do I put the cooler from the trans to the upper radiator port?
or
Do I put the trans cooler on the lower radiator port?
is this correct?
or
