Re: Transfer case compatibility
I can't speak to compatibility specifically, but here's my suggestions / limited knowledge.
The Astro case uses a slightly different chain. This shouldn't affect interchangeability at all, only replacement parts (if and/or when you need them).
It seems every model year of Astro & Bravada (and the Sy's and Ty's) had something different (its probably not every year, but it looks like every 2 years something changed). The front output shaft flange diameter and the rear output spline count were what changed.
I'd suggest you take a look at your current unit and do some measuring.
1.) Measure the front output flange diameter. I think the two options were about 4" and about 5".
2.) Count the number of splines in the output shaft (end of driveshaft). The choices there are 27 spline or 32 spline.
Then, have your vendor figure out whether the parts are the same or not. Get them to measure & count. They probably won't want to do it, but thats about the only way you can guarantee that the parts will interchange when they show up. Otherwise you'll be faced with either returning it or changing parts to make everything work (like swapping to a different flange on the propshaft or a different yoke on the driveshaft, neither of which are free).
'Dreamin'
