curious as to what the procedure is for installing a freshly rebuilt trans and new tc into the truck is.
should i prefill the tc? the trans? if so, how much fluid should i be looking to use?
i have heard the tc should "click" twice while being slid onto the pump shaft, and may require to be turned a bit while installing. is this correct-ish? also, i have read to not sinch the tc down using the trans/engine bolts.
i am looking to get new hardware is grade 8 sufficient for the trans to engine bolts?
any other items i should be looking out for during install?
thanks guys.
chad
thanks guys.
chad
