Trans case cooler fitting size?
G
Guest
Guest
Dose anybody know the size and thread that the trans case comes with?
Thanks.
Dan
4C FED
Absolutum Dominium
1/4 NPS, but if your looking to changeover to braided steel -AN lines your going to use 1/4 NPT fittings.
Lynn D. Brown
Dan,
I put #6 AN braided on my return line, and used a 1/4" x #6 - 45 Deg fitting. Don't think a 90 will work.
Of course U could use a straight adapter and go w a 45 hose end also. Kinda tight up there, I had to remove the heat shield to get a wrench up there.
