Tranny pump Question
Guys, have a question about my pump in the tranny.
I took it apart and found the surfaces were the slide and rotor ride scored to the point that it will catch my fingernail. Is this acceptable, if not what are my options(both halves are scored), reman or dealer, Also are our pumps just standard 700R4 pump(87up) for replacement purposes?? Thanks ahead, Fern
jwaller
Evil Genius/SyTy Guru
I always replace them if anythingis questionable. it's only about 100 for a good reman then you do all the good stuff to it. and make sure to get an 88 -91 to be safe.
Thanks for the reply guys, thats what I was lookin for. Ill replace it, John you ever have problems with the reman pumps??
jwaller
I havent. but thats bc all I really want from a reman pump is the grinding they do to them to fix the warpage in the pcoket and pump faces. The lineups spings, rings, seals bushings and other stuff I do myself.
