Finallyaty
I just torn apart the front susp. Put in new torsion mounts, upper and lower control arm bushing, shocks, upper and lower ball joints, idler arm, pitman arm,and inner and outer tie rod ends. The drivers side front is sitting 26 1/4 from ground to cladding, the passengers side is 27 1/2 from ground to cladding with the torsion screw set exactly the same. Do I have a worn out torsion bar or what. I haven't dealt with torsion bar suspension much but I would think they should be the same. I left the sway bar off until I get it to sit straight. Part if the reason for the rebuild was to fix this and I think I made it worse.
Any suggestion would be great. I want this done so I can start on the fun stuff.. The motor.
Thanks
Thanks
