Torsion bar mount?
Peter W.
I know it has been posted before but I am LAZY!!!! :D Can someone please tell the best torsion bar mount to buy to replace my stock ones? Thanks in advance!!!!
TYTILIDIE
METH HEAD
Re: Torsion bar mount?
Know that when you go to do this there is a very good chance you wont be bale to do the pass side one w/o pulling the torsion bar cross member. I have tried and tried and tried and can NOT get that one out to save my life.
95xtreme
hmm I have never had a problem, but each truck is different
EDIT: Also I just use stock replacements since new is such an improvement, :tup:
Flyin Ryan
hated cuz he drives fords
same here never had a problem and believe i used oem replacements
Sy777
Moog...and if they don't have typhoon or syclone in the puter then get ones for a bravada
Peter W.
Did you guys realize your truck all over the road before you replaced your torsion bar mounts? I hear like a clunk sound sometimes underneath my feet and on the highway the truck is all over the place and the alignment was just done? Do you guys think the bad torsion bars mounts could cause this to happen? Thanks
Slow TY
When I had to replace mine I used the moog ones, pulling the old ones out was a pita, I had to tear them apart which wasnt that hard, installing the moog replacements was pretty simple though. It took me roughly 2 hrs to do on my truck. I would say try having someone rock the truck side to side while looking underneath, you should easily be able to tell if they are bad. The symptoms you are having sound identical to my problem.
Cheapest I found the mounts was here Rock Auto
kraus
does it sound like the back bumper is loose banging ,cause if that is the noise your talking about my wifes ty has that same noise.It is loud as crap.Maybe I should check torsion bar mounts out.What should I be looking for by thes mounts ?
gkrcr882
SyTyless......for now!
If you hear/feel a clunk on right turns, the left is bad
If you hear/feel a clunk on left turns, the right is bad.
