Tool Check
Gr33n
waiting
Just want to make sure I have all the right tools to change my shocks and add a sway bar tomorrow. It's supposed to be sunny and 76 so it'll be a good day to work on the ty. What tools do I need to change the socks and add the sway bar? anything...odd?
SY2932
Administrator
Re: Tool Check
Everything *should* be pretty straight forward. Depending on how deteriorated the bushing are on your rear shocks, they may require some "persuasion" with a torch or cut off wheel. The steel sleeve inside the bushing that slides over the leaf spring perch is known to get frozen on there from time to time. If you don't remove the old one, you will NOT be able to install the new shock. It MUST be removed.
I apologize in advance if you are aware of this but I will say it anyways: if you are going to install those lowering blocks while you are messing with the shocks, DO NOT support the truck by the rear end when you remove the U-bolts! The result will be smashed cladding at best and you getting injured at worst!!! Support the truck under the frame with jack stands and be sure to disconnect the leveling dealio. Write up on it here Dang, Sunny and 76 degrees out, I wish
Gr33n
waiting
Re: Tool Check
ok...i'm trying to take off the old shocks and i think the bushings are frozen to the leaf spring perch. so in other words i need to cut them off and get new bushings?
Gr33n
waiting
Re: Tool Check
and also, does anybody know the hose connecting to the stock shocks? what does that do?, and what do i need to do with it?
Gr33n
waiting
Re: Tool Check
and one more question...which way is the top supposed to be angled? there is room between the place where the bolts go and the metal...
