Re: to dip or wrap?
Typically dip is only tough to remove if not sprayed thick enough. It takes a lot more than is needed just to color the vehicle/part.
If its 1k for instillation of wither go with the wrap. I'm a BIG fan of dip, but has its place, and longevity isnt it. Its more for those that like to change color often.
As far as installing goes both are about equal. Dip takes a TON of masking to do properly, wrap is just a lot of work itself.
You do have more flexability in color when using dip as you can get clear dip and add tints or pearls to make whatever you want. Wrap has a ton of options too, but the fancy stuff gets expensive quick. If its a simple color, say black or red, for the same price, then wrap is superior.
Wrap is a better product, even dippers will agree. Its also usually more expensive and can't be changed quickly. But, as said cheap wrap has a lot of problems too.
Oh, and remember, dip stains and is VERY touchy around gas, wrap is more forgiving.
