Timming issues
NeedaSY
Go Ahead N Go
Timming the distributor. when i use the timming light and line up the marks on the crank and idicator the truck is idle at like 2,000 rpm witch i dont understand???
SY2932
Administrator
Re: Timming issues
You did disconnect the "tan wire with the black strip" under the dash correct?
"The ESC Electronic Spark Timing "tan wire with a black stripe" that everyone can't find when attempting to set their timing (s-series). Wire is under the carpet on the passenger side below the heater box. It is disconnected to set the timing, then reconnected."
Re: Timming issues
try resetting the ecm by disconnecting the battery for a minute of pulling the ecmb fuse, and see if it helps
Re: Timming issues
That comment has been on here for years. Technically I have no idea if that's necessary. However I have not seen any difference, and, I was told by a GM tech that what it (removing the fuse) -does- do is cause the IAC to have to re-learn. This, of course, may or may not be a good thing in this case. So I'm as confused as ever.
Setting the timing as instructed and having no vac leaks seams to make the most difference IMHO.
