E.Murray
Re: Timing advance and boost - DM vs. plugs
intheclouds,
I pulled the boost back out and have backed off all settings, but the wavy boost is still really noticeable. As far as Datamaster, I've had a heck of a time with it. On one laptop (Windows 7), it will not monitor anything except the fields at the top. On an older one (with XP), it was working fine, but now will *only* monitor. Every time I try to start, it just goes into monitor mode. Then when I try to make a run, it locks up for the first 5-7 seconds of the run and doesn't record anything. I haven't bought the full version and am not going to until I can get it to work. On both, I'm still within the free trials.
Eric,
Adjusting the actuator helped with the wgdc, so I'll give it another turn and a half. Once I get that resolved, I may contact you about a chip re-burn. I'd like to know, though, if I would gain anything (or lose anything) by going with a separate controller. I need to order a boost gauge and can get either a normal one from AEM or one with a built-in boost controller and replacement solenoid (their Tru-Boost). If it would just duplicate what the chip is already doing, though, that would be a waste of money. I'd almost rather have everything controlled from the VeloSyTy chip since it works so slick.
intheclouds,
Eric,
