420
Broke Ass Racing
It’s time to sell the Monster – Syclone # 2579
First - Contact info. Matt @ (954) Four One Oh - 5139. Text or call ok.
Due to medical issues, I am going to have to finally part from the monster I have been building for many years now. It is very painful for me to let it go before I get it finished, but I imagine, by necessity, it will go to someone who can appreciate what I have been trying to do.
Please let me be clear up front: This truck is not for the faint of heart, wallet, or skill. This truck was being built to contend with Robert for title of Fastest AWD V6 Syclone. This is not a 10 second build. This is for someone (else) who is truly and seriously nuts. Oh, and wants A/C, a stereo, and overdrive to go with that power. The 76mm turbo on the truck is what we were going to use for “training wheels”. This setup is spec’d for an 88-91mm. I have run it out to the beginning of third a couple of times. Boost started at 12, crept to 14 through the run, and as it sits right now, it's a 10 second truck. At 14 lbs. It will make 28+. Think about that for a moment.
The truck has in excess of $112,000 (not a typo) invested, not including my own wrench time. Nearly everything on the truck is either custom, a prototype, or extremely expensive and/or hard to find. It is 90+% complete, runs, drives, and scoots really nicely for a baseline tune and just sitting on the wastegate spring.
Truck has approx. 500 miles on it since everything went together. I took it out about a month ago to go see a friend across town. Only real issue I had was badly flat spotted tires, and a bit of uncertainty about the reading on the fuel gauge. Needs a voltage check on the sending unit.
In order to get this truck moved. I am open to plans A, B, and if necessary, C.
A) I am asking $40,000 for the truck as it sits. This is by far my preferred method.
B) I would consider selling the truck minus the trans, rear, and XFI for $30,000. If you have these pieces sitting around, this may be a more cost-effective option for you.
C) If it absolutely comes to it, I will part it. This would break my heart, but my family and wallet have to come first on this one.
I will work with any serious buyers regarding pictures, video, inspections, and anything else. I'm not posting any now in case someone is looking to keep it a street sleeper and make a couple of bucks with it.
Mods are as follows (basic list, much more done. I KNOW I’m forgetting stuff):
311 cubic inch V6
(This engine was originally built by John Waller. As the other two bowties that left his hands showed some issues, this engine was gone through thoroughly. Passed a leakdown and compression test, and we had both the heads and the pan off. No problems found. Finally, it was confirmed that there was a different machine shop that did the work to mine than to Jamie Hacking’s and the other motor Waller built.)
Bowtie block, sonic wall checked before being machined
Billet stroker crank
Oliver Billet rods
JE pistons, coated
King bearings
Parts cryo treated
XFI 2.0 with traction control and data logging, individual EGT probes per cylinder, and TCI transmission control. Full Harness.
E85 flex fuel sensor, allowing truck to run any combination of E85 and pump gas without changing programming
BeCool 1000 hp setup
Custom hot and cold side turbo kit
Precision Turbo GT4276RL DBB – 76mm turbo, hot side coated, cold side polished
HKS GT II wastegate
AMS 1000 with Dedenbear CO2 setup
4” electric cutout on downpipe (frame notched to fit downpipe)
Rossler 4L80E with custom 2.10 1[SUP]st[/SUP]/ 1.76 2[SUP]nd[/SUP] gearset, automatic valvebody, and transbrake
Precision 10.5” 3600 stall converter
Fully built transfer case, including Prime Gears 5 pinion billet planetary and sun shaft
Carbon fiber driveshaft, custom length for 4L80E
Custom length 4L80E propshaft
Custom rear end with Moser Fab 9 housing and GM quick change 3[SUP]rd[/SUP] member (3.42 gear)
Dual Trans coolers with fans
JS machine coil over kit
Flex a form fiberglass springs
Battle Bar traction bars
QA1 single adjustable all around
MSD HVC II Coil
MSD Pro Billet distributor
MSD Digital 7 Programmable
Firecore 50 wires
Magnefuel fuel pump (believe 4303, need to double check)
Alky control custom single nozzle setup
All braided stainless fuel line
16 gallon fuel cell (bed mounted)
5 gallon alky cell (bed mounted)
PTE 95lb injectors (installed)
Billet Atomizer 225 lb injectors (not installed, new in box)
Custom Aerospace components front brakes, and Aerospace Components rear brakes (4 piston all around)
Sparco Flash 5 steering wheel with adapter
Meziere electric water pump
All billet aluminum pulleys
ZQ8 quick ratio steering box
JS Machine solid motor mounts
Aluminum tubular Core support with custom fiberglass headlight buckets
Aerospace components vacuum pump kit
Powermaster 200amp alternator
System 1 permanent cleanable oil filter, billet
FireBottle 3 nozzle system (2 in engine bay, 1 in cab)
16” BBS LM2 wheels
Custom carbon fiber wiper cowl, as well as stock steel wiper cowl
Custom carbon fiber tailgate (pin in, non-functional). Weighs *3* lbs. Not installed.
Battery in sealed box (bed mounted)
Custom wiring adding main disconnect, and laying out all relays and fuses on carbon fiber board
A/C condenser relocated to bed floor, with 2 fans under pulling air
TRUCK NEEDS
New Pin on hood (Shop cracked old one)
Bed cover (old carbon fiber one destroyed when I tried to remove paint)
New tires
Dent in passenger side bed
4 pieces of cladding replaced. I have three, just need to verify which.
Paint
Someone to double check AMS 1000 routing and program it
Good tune (I can provide several XFI tuning recommendations if needed)
Spare underwear
311 cubic inch V6
Oliver Billet rods
JE pistons, coated
King bearings
Parts cryo treated
HKS GT II wastegate
MSD HVC II Coil
Firecore 50 wires
16” BBS LM2 wheels
TRUCK NEEDS
New tires
Paint
Spare underwear
