throttle body leak
idle has been hunting, did a leak test and replaced a couple things ( egr delete gasket and vacuum plug on backside of TB)...found out there was a leak in the shaft of the TB where linkage goes in. If theres not an easy fix after I search here, does anyone know the BBK replacement part number, and would I need anything else if I buy that?
stock turbo / a/c delete etc.
Mtn Z
Re: throttle body leak
I know there is a guy who rebuilds and ports the stock throttle body while sealing up the shaft with new bushings so it doesn't leak. My buddy on here has had his done before. You might want to PM him about it. He goes by SRT NOT. His TBs came out beautiful.
sy#2921
BAMF
Do a search for Matt Blum. I just got mine back about 2 weeks ago from him. Excellent guy and super fast turn around. Took less than a week.
TYTILIDIE
METH HEAD
X10, he did mine and I was very happy with his work and service. Outstanding guy! :tup:
Flyin Ryan
hated cuz he drives fords
mpettograsso said:
Has Anyone Used The Arizona Speed And Marine Tb?...i Think Its A Direct Replacement 54mm.
Ralph (visiousV6) is using one I believe but I don't remember it being a bolt-on.. might want to ask him
TYTILIDIE
METH HEAD
AUSyTyIN said:
What's the cost of something like this?
Something like what? I paid Blum $140ish? and he did everything I asked him, bored it out, installed new bushings, and plugged off the vacuum ports.
sy#2921
BAMF
When I just got mine done it was in the 140 range as well. Bored to twin 52mm, new buttery flies to match, bead blasted, hot tanked as well, New bushings, modified the shaft for less restriction and a custom plate with syclone and my truck number.
jbone
Got mine from Blum also, nice guy great turn around, and excellent work!
he called me back right away, but i missed it. probably going to use him on everyones recommendation, but i found that ARIZONA SPEED AND MARINE is blowing out their CNC billet that was $595 for $295.........although more pricey than what Matt can do, its a good deal. they have 3 or 4 left at that price.
sy#2921
BAMF
I just checked their site and it says $395. Not doubting you but got a direct link by chance?
