Third hole on Waterpump
My factory waterpump and block has a 2nd hole on the passenger side of the waterpump (toal of 3 passages). I went to install my factory water pump on my Vortec block but I have only has the center holes (one per side). I have a 2 hole water pump gasket, but it would go no where on the vortec block.
Could this cause a problem, do I need a different waterpump?
Here is a picture of my stock motor.
Re: Third hole on Waterpump
I don't believe the lower hole enters the water jacket. i.e nothing should come out. Here is a replacement pump for a 98: http://www2.partstrain.com/includes...R01CLkpQRw==&title=R01CIFdhdGVyIFB1bXA=&text=
Doesn't look like the flow holes are any different.
The 98 pump looks like 03 pump that came on the jnkyard motor. The hole on my original block, almost looks like its a dead end but I doubled checked it with compressed air and it definates goes into the water jacket.
TYHOGG
Not a bad idea. Is the hole small enough to tap and screw in a plug?
sytyguy
Moderated User
I meant the top hole on the water pump. Not the top hole on the block. The pump I listed will accommodate the block, but it has an extra hole on the top for a heater core feed. Since our intake has our heater core feed outlet, you can either block off this hole or block off the intake and use this hole.
I think I may have confuse you, here is a picture of my factory LB4 water pumps and the third hole on the passenger side.
Here is the Vortec Block I am trying to mount it to.
sytyguy
Moderated User
Did you get the fan clutch/pulley from the new engine?
if not, modifying your current pump might be more desirable as I've yet to find a pump with an omitted 3rd hole and our style pulley/clutch. I'll keep looking though.
I do have the water pump & pulley (different nose) from the new motor. I have electric fans, so the clutch isn't need, but this motor didn't some with one anywyas. I was kind of hoping to just bolt mine on.
TYHOGG
Sorry had it backwards. If your doing the extra work why not upgrade to the edelbrock for the extra cooling?
