Thinking about trans cooling.
jusssi
Ok, Ineed some opinions about this; is it good idea to delete original in radiator trans cooling and go with large external unit? Now I have original and small add cooler. Another question is that which way it should be; first to radiator and then to add cooler or otherwise?
the baPhoon
Re: Thinking about trans cooling.
It is imparical to add a decent trans cooler to keep the stock trans alive if you plan to mod.
Even stock trucks can benefit from a larger heater.
Quickstop [UK]
Combating adversyty.
Keep stock cooler.
Add the new cooler.
Shouldn't matter too much which one comes first. The size of the new one will determine where you put it. What are you planning for the lines?
