wildphil
I Love My Ty's
If you own one long enough.
I finally had time to fix my oil gauge issues. The new oil pressure switch that I installed after the rebuild was no good. The replacement one did the trick. This was after flipping the gauges needle back in place and removing lots of stuff so it could be replaced.
After I get everything back together. I fired the truck up and it ran for a few seconds and died. Of course it would not restart.
After some checking I found the fuse blown for the fuel pump. During the oil pressure switch replacement. The fuel line was removed from the fuel rail and moved over to gain access. And after reconnecting the fuel line. I ran the fuel pump to check for leaks(learned this lesson the hard way). Must have blown the fuse during this operation.
Truck fired right up with a new fuse. I let the truck get warm enough for the electric fan to kick on. I checked under the hood just to make sure everything was fine. Then I noticed only one of the electric fans working. I shut the truck off and went in the house.
