It’s a bit too tall to fit in there with the added swivel.you might be able to use a 3/8's drive with a swivel socket on the end.
Thank again, Keith.![]()
Changing the Thermostat on a GMC Syclone
The thermostat is part of the cooling system that regulates the temperature of the system by regulating the flow of coolant in your radiator/engine. It also helps on engine wear and emissions. The valve on the thermostat works with the combination of a cylinder of wax. This helps open and close...howtune.com
It’s locked in there fairly tight. Nothing some penetrating oil won’t fix. Thanks for the tip. That should do it.remove the vacuum line fitting thats in the way
Don't break the bolt off in the manifold. It happens. If the thermostat is performing correctly, and the housing isn't leaking, perhaps consider just leaving things alone?It’s locked in there fairly tight.
