The truck is running....
protosy
.... after being down for almost 4 years. I am glad to have it together more or less finally. Its been quite an ordeal (mostly due to one mr al dustan ii). None the less, I was able to overcome all of the challenges, and am pleased with the results.
Thanks to Marty, Mike Lee, John Waller, Merk and all the others that helped me out along the way.
Chassis/General-
Body off, ground up rebuild
Media blasted/por 15'd frame
New poly bushings all around
All new brake components front and rear
New shocks
Tons of new hardware
Motor-
Ported/polished heads
2.02/1.60 valves
Full roller rockers
Custom cam
96lbs/hr injectors
FAST ECU
Ported intake manifolds
60mm DBB innovative turbo
RPM downpipe/minigate
Innovative MSBC
Ceramic coated manifolds
Powder coated brakets/intakes
4 bolt splayed main caps
Treated crank
Oliver rods
JE pistons
Soon to have LS1 coil packs w/custom crank/cam trigger
Drivetrain
Buckshaw TCC controller
Built transmission
New front differential
New front prop shaft
New bravada smarttrak transfer case
9/11 2800 stall converter
That is more or less the highlights of it....
Some pics are below. (Please ignore the missing grill letters and other small cosmetic details, as I have not had time to finish those up yet).
BigBadSmoosh
do you need a gm for the gmc on the grille?
I have a good M.. but my G is kinda messed up, if you want the G its free, if you want the m, im sure we can work something out.
the truck looks nice.
Boosted
Nice reflections in the paint. Great evening picture.
Question:
Cladding? Fender flares all the way around? What do you have in the back for bumper cover or Roll pan?
protosy
Sure that'd be cool. I will pm you.
protosy
Question:
Good question.. The fender flares are on there just as a test, I think they are coming back off.
The truck never had cladding on it, and probably never will. I am using the stock rear bumer though. the stock bumer that weighs in at .... 500lbs (not fifty, five hundred.) .... is not going back on.
chad
protosy
Syclone#1992 said:
Looks great Chad!!!
That paint makes a world of difference....who did you end up having do it?
Actually, that is the same paint with a few hours of wheeling and such. I am going to paint it this winter.
chad
