TE-44 turbo is in now what??
92boostedty
Senior Member
hey guys i just got a te-44 put in as well as a 3" dp ,test pipe and the rest of the exhaust is 3 inch...i have stock stall and stock injectors ultimate chip, afpr, apr upper intercooler and bigger lower, big sure flo pump blah blah.... so what do i do next i havent driven the truck yet but my mechanic (turbo junk) is telling me its only making 2 lbs of the line... do i need to get bigger injectors and differnt chip? just a bigger stall? what do ppl run with this turbo?
thanks
tygraine
team green racing
Re: TE-44 turbo is in now what??
I would think a bigger stall would be a good idea 2800 or so..just my opinion.
skwayb
NWSTP
Wastegate adjustment sounds like needs to happen. Maybe even some Wastegate Duty Cycle changes in your chip.
R&C_RallySyTy
Little Big Man
Yea, I'm not sure with a TE44, I used to run a TE45A and could boost 8-10psi off the line before I even moved. Then again I think I had a low 3k stall and turbonetics wastegate/blow off. Your boost problems won't have anything to do with injectors, but when you do push the turbo its possible you could need more fuel. Personally I would have to say its either stall or what the other guy said. If you do need injectors I'll have a set of 50 lbs. used for about 1k miles. I need to upgrade to 84 lbs. with a 67 billet turbo.
cheatham2492
You need a looser convertor "more stall". I used a "bad dog"20g and I couldn't get more than 2 #.
Untill I changed the Stall.
Common problem when you use a bigger turbo. It takes more energy to move the turbine wheel.
The bigger the wheel,the more the lag
HTH
DC
92boostedty
Senior Member
So do you think I can get away with a higher stall and turning the fuel pressure up to get this thing moving?
BoostedSUV
put a 2800 converter in and adjust fuel pressure accordingly... that should be good to get you rolling along pretty good for now! Converter is everything with these trucks and larger turbos. with out it you're not running to your potential.
