Double12
AstronautCowboyMillionair e
Had a new torque converter installed because the Ty was violently shuddering under TCC lockup with moderate load. Well this did not solve the problem. Any ideas here? it is behaving exactly like a bad TCC... Only shudders when TCC is locked and you try to moderately accelerate. Lightly tap brake while accelerating and the shudder stops. I should note that the problem initially appeared after a head gasket change, and since then the Ty is stumbling a little. Related problems or coincidence? Any help would be greatly appreciated.
Thanks,
Dan
Thanks,
Dan
