We have a manual lockup switch but it doesn't do anything, the torque converter is not locking up at any time. The transmission shifts hard and other than the lockup it works well. Coolant running about 180 degrees, but that shouldn't matter with the switch. So far I've checked out the switch on the brakes (the one next to the brake light switch) and it seems ok.
My next guess is to pull the plug off the transmission and check it, but I'm not sure what to look for - should it have 12v when a lockup signal is present? Is there a way to check the solenoid? I assume it should just read close to 0 ohms?
