Re: SyTy FAQ that I wrote
dgoodhue said:
I have been writing up a basic engine/newbie FAQ. Their used to be one on the old syty.net and I finally got around to doing one after about 3-4 years of saying I would. This also might be a worth while post and/or sticky for the newbie section. Please critique, my writing, my information, & omissions. I won't be insulted.
http://www.corvetteforum.net/c4/dgoodhue/syty_faq.html
Thanks for asking (hope you dont take my suggestions personnally, in fact
Im wondering if their applicable myself - or if "volunteers" could assist you in writing
up some of these things);
A Syclone/Typhoon owner "probably" needs to know the following:
-a bit about the factory turbo including wastegate, boost and "3 bar" terminology
-a bit about the ECM (boost learning, limp mode, knock etc)
-a bit about the IC (pump failure, IC rerouted lines, MAP temps etc)
-a bit about fluid temps (160 thermostat, fans such as spal, and under the hood temps)
-a bit about tranny (Drive vs OD, TC Lockup, tranny temps, lubeguard, etc)
-a bit about air filter (stock inlet, K&N upgrade, Kenne Bell Upgrade, battery relocation)
-a bit about importance of voltage (alternator, undrive pulleys, starter/solinoid, relay, etc)
-a bit about driveline (AWD wheel dia matching, propshaft upgrade,
-suspension - torsion bar adjustment, rear springs/lowering, sway bars
front steering stablizer, stock shocks vs coilovers)
-a bit about key gauges (temp, boost, fuel pressure, whatever)
-a bit about modifications (S10 wheel cyclinders, motor mounts, grease fittings,
proper alignment, spark plugs/cap/wires, afpr, fuel pump, vacuum lines,
blade of death, traction bars, Elephant Ear/Mirror Replacement, Graphics Replacement
cladding cleaning, etc)
-and a bit about vendors (those on this list who know SyTy's, vs generalist).
Ive always thought that new owers go through the same type of stages,
where 1) learning vehicle (launching, handling, debugging, terminolgy/meaning, etc);
2) cosmetic enhances (wheels/tires, fit/finish of cladding/paint/interior/bed cover)
and Vin Number/Vehicle Sequence Number relationship (with differences between
91-93 like red/black grill letters etc) 3) minor modifications for performance
(like 20g, ultimate chip, etc)
Anyways, I could be wrong - meaning that the above info is known by everyone
and thats the reason they bought the vehicle (SyTy) in the first place
BTW, Ive always enjoyed your posts!
-Larry Brown
