syty engine strength
If i were to put vortech heads, a 412 cam, and the rpm bolt on stage 3 turbo wiil the stock internals be able to handle that? And what about the tranny how long would it last with that kind of setup?
MikeRenz
not stock
Re: syty engine strength
stock internals will last pretty long if you don't detonate at all. Tranny will come down to luck/how you treat it.
FxsX24
94 S10 to be lowered/v8
AKA it will break unless you dont drive it, or sell the truck to grandma
They break pretty quick if you do detonate. The trnasmission of more of when is it going to break.
James Thomas
"NO CLASS"
As posted above, it's all in the tune and maintenance. You can break an anvil if try hard enough but the turbo 4.3's are pretty tough ........ if you don't detonate it like dgoodhue says. There are a lot of SyTy's on here that are driven often if not daily, driven pretty hard on the street and banged on pretty hard at the track. Look up a few of the posts by Tooky, his bottom end is stock (I think) and he has some pretty good top end mods like heads, minor porting PTE 52 (I think) etc. and he races the piss out of that truck, but....... he never goes beyond the safe limits, has FP, WB, ACCURATE boost gauge and logs and watches real close to every run.
________
James
