Syclone rebuild help
Transdamn
Does anyone have a picture of the oil pan or bolts that hold the oil pan in place? My engine builder gave me a box of mixed parts and i cannot remember what bolts went where... Also where did the 3 bolts with nut in the middle go? I either have timing cover bolts or oil pan bolts right?
Thanks!
SikVSix
Re: Syclone rebuild help
3 small bolts (1 slightly bigger) probably went to the fuel pump block off plate (these also have knurled shoulders to keep from backing out). You should have a bunch of small bolts (10 maybe) for the oil pan, plus a few studs with nuts for some of them. then the corner studs are a little bigger. Then theres the 1 pc rear seal adapter thingy, that thing has 3 or 4 different bolts/ studs for the 4 holes in it. 3 small and 1 bigger one. I'm not sure what the stock timing cover bolts look like as mine were gone. There are some 3/8-16 tork head studs in the heads back and front.
thats about all I can think of right now.
Transdamn
Truck is getting together slowly. More questions though!!!!!
#1 Where and what are the part numbers for the oil cooler line to be able to run the braided steel lines?
#2 What about the braided fuel lines?
#3 does anyone have part numbers for the plastic valve covers?
Thanks for the help and i searched but the site has 1 million different opinions.
Transdamn
Truck is painted, engine rebuilt, and ready to finally be driven. A truck is picking it up from Michigan where it was hiding for a nice tune tomm morning. I am very excited and cannot wait to get this thing on the road.
