im selling my syclone with many bolt on upgrades, 105,000 on body runs and drives perfect always been serviced body has no rust is 8 out of 10 interior is 8 out 10 no ripes in seats can drive anywhere $12,000 im located in nj 856-nine7nine 6021 38MM TIAL WASTEGATE $350
PRECISION 6262 TURBO $1000
TURBO TWEAK CHIP FULLY ADJUSTABLE $120
60LBS INJECTORS $329
METHANOL/ ALCOHOL PROGRESSIVE ADJUSTABLE INJECTION 3 GALLON FUEL CELL IN BED FOR WITH LOW LEVEL LIGHT $750
MOVED BATTERY TO BED $50
3" DOWN PIPE $200
3" EXHAUST $400
POWERTRAX NO SLIP POSI $500
TRACTION BARS $350
NEW REAR BRAKES WHEEL CYLINDER & DRUMS $200
DRILLED AND SLOTTED ROTORS $225
NEW CALIPER & RUBBER BRAKE LINES $200
B&M TRANSCOOLER FRONT MOUNT $200
DEEPER TRANS PAN $60
NEW WINDOW FELTS $120
NEW DOOR SEALS $100
B&M CONSOLE SHIFT
AUTOMETER BOOST VACUUM GAUGE $50
AUTOMETER ELECTRIC FUEL PRESSURE GAUGE $170
WIDEBAND AIR FUEL GAUGE AEM $200
TACH DIGITAL RPM SHIFT POINT MEMORY $40
NEW TURN SINGLE LENSES $50
NEW FRONT AXLE SEALS
HEAVY DUTY FRONT DRIVE SHAFT $450
FRONT AND REAR DRIVE SHAFT LOOPS $300
LEATHER BED COVER $500
WHITE FACE GAUGES $100
METAL 2" COWL INDUCTION HOOD $600
HAD BUMPER COVERS REPAINTED $1000
LED HEAD LIGHT KIT $150
MOTOR WAS REBUILT FROM PREVIOUS OWNER $2200
TRANS REBUILT $1000
ALL 4 NEW TIRES $600
ZO6 17" VETT RIMS $500
SFI FLYWHEEL $50
ADJUSTABLE BOOST CONTROLLER INSIDE CAB WITH BRAIDED HOSES $100
4" K&N AIR FILTER RAN THROUGH PASSENGER SIDE FRONT INNER FENDER WELL $100
TINTED WINDOWS $300
KENWOOD CD PLAYER $150
UPGRADED COOLANT FAN MORE BLADES, $75.00
3BAR MAP SENSOR $80
2600 STALL CONVERTER FEEL LIKE STOCK STALL
BILLET REAR AXLE COVER WITH GIRDLE PUT A LOAD ON REAR AXLE MAIN CAPS $125
HOTWIRE FUEL PUMP KIT $60
AEROMOTIVE INTANK REPLACEMENT PUMP $190
NEW FUEL TANK WITH CUSTOM BAFFLE $150
SIDE WINDOW VISORS $60.00
3" DOWN PIPE $200
3" EXHAUST $400
TRACTION BARS $350
NEW DOOR SEALS $100
B&M CONSOLE SHIFT
TRANS REBUILT $1000
SFI FLYWHEEL $50
TINTED WINDOWS $300
3BAR MAP SENSOR $80
