SX performance fuel pump and filter
nallj92
I have some parts hanging around in the garage from a chevelle build i just finished up.
I have a Sx performance fuel pump model #18203. This was used in the chevelle for 200-300 miles. it has -10 AN inlet and outlet's it goes new for about $320
the tech sheet is here
http://www.fluidsystemsengineering.c...productid=3811
Supports carbureted engines up to 1300 HP and fuel injected engines up to 1000 HP at 45 PSI
Ultra high-flow rates exceed: 80 GPH at 12 volts and 45 PSI, AND 120 GPH at 12 volts and 10 PSI
Flow-thru design maintains maximum cooling, produces outstanding reliability, and provides consistent fuel delivery from idle to full throttle
-10 AN inlet/outlet fittings for easy installation
For use with gasoline or alcohol fuel systems
For race or marine use only
Not for use with reduced sulfur content diesel fuel
Passes UL standards for Coast Guard approval for use in marine applications
Available in Red and Black
Asking $200
I also have another pump, bought to orginally run dual pumps on the chevelle, but changed directions. This pump is #18201. It is same as the 18203 but a older model #. It flows the same #'s
Asking $150
I also have for sale a SX performance filter model # 41001. The newer part # for this is 41002 and info can be seen here.
http://www.diyautotune.com/catalog/s...ter-p-296.html
Asking $40
