Re: Stock turbo after 20psi
Another one bitten by the "BARO Bug"!!! Look in the upper right corner.
BARO 57.2!! I just talked about this a week ago in another post. I also explain it on my Tuner's Guide to DataMaster at
www.powertuneplus.com.
You weren't at 25 PSI. The BARO Bug throws everything off including the tune. You gotta know when to trust your datalog and when NOT to trust it.
Your boost control looks goofy and wavy like a roller coaster, I've posted a lot about that in the past too (thats exactly how my truck was when I used the electronic stock control, it sucked!). My solution was to use a $40 Boostvalve.com controller. Yeah you lose the Ultimate pushbutton control but it always worked like shit for me in the first place, so no big loss there. The Boostvalve was one of the *ONLY* mods I ever did that truly bolted on and IMMEDIATELY made a night and day difference without any additional "gotchas".
The topic of this thread was about going past 20 PSI on the stock turbo. It's not just that you're heating up the air. You have to think about the exhaust side too. There's a point of diminishing returns and then a point where you are harming yourself more than you are helping (as boost continues to rise). The exhaust backpressure starts to choke the turbine, and when the exhaust valve opens, you could get exhaust bursting backwards into the cylinder (briefly). The turbine designs have a lot to do with the aerodynamics of the fins. It's sort of like a camshaft. A cam that is good from 3000-6000 is going to drop off at higher RPM. If you keep winding it out to 8000 RPM it will absolutely choke the motor and kill horsepower dramatically. No way around it. Turbos are the same way in my experience. A turbo is optimal in certain range (this is what Compressor Maps are for). If a turbo were good at higher boost it would have to be trading off power at low boost (relatively speaking), just like a camshaft. You probably already knew that a race cam (designed to make great power at high RPM) has a tradeoff of making WEAK power at LOW RPM. There are no "magic" parts that just make more power everywhere with no tradeoffs or compromises/drawbacks.
Going fast is ALL about managing your tradeoffs to find the best balance for your goals.
For me the limit of my stock motor, stock turbo was 20 PSI on my autometer gauge. But keep in mind the differences in altitude, differences in boost gauges (I have had several Autometer gauges go bad up to 2-4 PSI off), differences in Datamaster readings, MAP sensors, and slight differences even across stock engines and stock turbos. (perhaps someone has a slightly tight/loose timing chain, advanced/retarded cam, distributor timing, better/worse ring seal/compression, etc.) So some people have found 18 PSI to be the fast limit of their stock turbos and others higher than 20 PSI.
But if your fastest DM QMC is a 12.7 @ 104 then you still have a lot left in your stock turbo IMO. I ran 13.01 @ 102 with a stock chip, and 12.7 on an ATR Pitbull chip. It seems like everyone who really worked out all the bugs in their stock trucks were able to reach mid 12s or better on high boost with high octane and good launches/traction. I'm sure I could name 5-10 trucks like that.
I bet you are still running pretty rich at WOT too, and could gain more power by leaning it out via an alky chip tune.
