Stock Turbo Adjustment
Typhoon #2131
SAVE THE TA-TAS
Hello, I need to adjust my stock turbo. I'm only getting 10 to 12 lbs of boost out of it. The rod going to the lever on the bottom of the turbo im guessing is the stock waste gate do I screw it out or in to get more boost?
Thanks for the help guys.
Typhoon #2131
SAVE THE TA-TAS
Re: Stock Turbo Adjustment
so screw it in? thanks. how will I know if its to much? what you think turn it in a half turn at a time?
It's just a six
Super Member
When your boost over shoots of what you wanted, basically going too short does not allow the wastegate valve to open all the way, it will limit the travel of the wastegate valve, hence will decrease the flow rate of the wastegate.
Try 1/2 turn @ a time, just to be safe.
atkonkler
Is this your bush?
The rod end nut with the hole in it should be pulled over the wastegate lever. This can be done by pulling the wg lever shut and the wastegate actuator arm need to be pulled just slightly over the wg arm, slide the lock pin in the hole and drive it. Be cautious but you'll know when it over boosts. If it over boosts move rod out accordingly. Ask me how I know? and would you like to see my left arm and the burn scars on it now.if you want call me my number is 763-221-8138. The name is Aaron!
Typhoon #2131
SAVE THE TA-TAS
Ok I will give it a shot. Yes using the stock gauge.... I know I know they are not the best but it worked just fine and was reading 15lbs then I rebuilt the motor and now its only showing 10 to 12lbs and it dont feel like it has the power it did before. I didnt do much to the motor just .030 over bore and bigger injectors and some light porting on the heads. Even with just that I thought I would feel more power then before but no it actually feels like a turd compared to before the rebuild.
You don't need to adjust the turbo. I bet the tune is the issue. What size injectors are you using? What chip are you using?
0966Sy
Code what?
FYI the rod does not turn, only the turnbuckle (the thing with the hole in it that goes over the pin) loosen the nut first to make adjustments. Double check your hoses to the solenoid
Typhoon #2131
SAVE THE TA-TAS
I cant remember the size on the injectors. i know its like to sizes bigger then stock. still running stock chip. They told me i didnt do enough to worry about changing the chip
It doesn't work that way. Our trucks with the map based fueling needs to have the chip that matches the injectors. Your truck probably doesn't make full boost because its overly rich.
Typhoon #2131
SAVE THE TA-TAS
Oh really???? I didnt know this. I'm trying to learn about these turbo motors they are a lot different then the old fashioned carb motors.... lol... Well then you are right thats my problem because it is running very rich. I start it in the garage with door open and my eyes start to burn in the first min or so.
If everything else is stock beside minor porting of stock heads and 0.030 pistons, put back a good set of stock injectors in.
JAY
Here's my advice before you start adjusting the wastegate rod.
#1 Install a real boost gauge.
#2 Connect a data logging program on your truck.
#3 Verify if you have a stock chip, injectors, cat removed/modified.
#4 Check vacuum lines for leaks
