42 psi is the base fuel pressure. Stock ECM tries to control the boost at ~13.8psi, but its peaks in the 14-15psi range.
This is at idle with the vacuum line off and plugged. Fuel pressure will vary depending on the the vacuum on it, so always check with the vac line off.42 psi is the base fuel pressure.
:dunno: Well, that's the way you're supposed to do it. Or did you mean "on"?I don't know why, maybe I am lazy but I always prefer to set pressure with the vacuum line off. Just me though.
