Stock Part Availability
gkrcr882
SyTyless......for now!
How hard are stock SyTy parts to come by? The parts we would need are the upper and lower IC, the intake and manifold, exhaust manifolds, and the turbo. I'm just interested in finding out how hard it is to find these parts and in general what good used ones go for. This isnt a WTB ad!!:rotf:
DynaGlide
Ton-Eighty
The stuff really isn't that hard to come by around here. The only thing is that they probably will not be cheap. There are only so many of them made. I have, however, seen all of these things go for relatively cheap from time to time. If you're in the market for them, keep looking at the classifieds section.
Re: Stock Part Availability
This is the way I see the prices.
Just a upper/lower Intake $600, plus you going to need fuel, rail injectors, TB, brackets, sensors. You maybe be able to find a complete intake for $750-800
Do you need the ECM and harness as well? Accessories?
Exhaust Manifolds, $300
Turbo prices seem to fluxuate, I have seen from 150-300 for a stock sturbo (probably depends on the miles), you will also need the 2 coolant lines & 2 oil lines, as a well as a downpipe (50-75)
Upper Lower intercoolers, should be around $250. You will also need the upper IC brakes and lower CCHE housing.
If you looking for the stock intake track (air box crossover tube, 90 elbow), lately they have been going for $200, becareful of the crossover tube, make sure its not off a 125K+ (which when the seem to dry out and crack and why they are expensive now)
sy2675
He Saved the Pimp'n Game!
Ive got a stock trurbo off my 75000 mile truck as well as the stock downpipe for sale, make offer, not really sure what they are worth. I have the chip that was for the stock setup and the map sens i think. Let me know.
gkrcr882
we got a quote from RR for $8k for a full engine and install. We still have the ECM and the relays, including the IC pump relay
critical
meltdown
ive got a stock intercooler and all the components to go with if you need them.
stlSY
Truck RamRod
I have a whole running motor with about 4k mi on it. It is currently sitting in a 2wd in the classified section!
TYPHOONNUT
TYPHOONNUT
still have turbo 4 sale? doug
