Yep, mine is worse in park than in drive too. I guess this is because what BG mentioned in a post a while ago. There is only one table to dial in closed throttle fueling and the truck has to live with that one table both under load (drive) and not under load (park, neutral) conditions. Hence, AFR will differ...
My first priority right now is to solve this problem. I'll update with what ever I can find out. As of now, my vacuum leak theory seems to be wrong. I've replaced the throttle body and the upper-to-lower intake gasket and the truck behaves the same. Also IAC values seems to be good.
I'll try out what troy suggested, drasticaly lower my fuel pressure. If this helped, I'll adjust closed throttle fueling in the chip. It can take some time though, because my fan motor just went south on me. I've to take care this issue first...
Later,
