Starting T-56 Conversion
tippmann243
Re: Starting T-56 Conversion
jjorgensen52 said:
Hrrrm... I wonder if I should just try and find a 168 tooth wheel that is drilled for a 10.5" clutch.... that'd be easier
i 168 tooth flywheel will not fit in the lt1 bellhousing
and like i said earlier the lt1 flywheel is specific to the lt1 trans so if your using an LTx trans you MUST use an lt1 flywheel
Robert Lone
MUTANT
tippmann243 said:
is your trans lsx based or lt1 based?
when using an lsx based trans a stock 4.3 5 speed flywheel can be used (i recommend it also) along with a stock 4.3 starter
Mid 90's Camaro...that's all I know. :tdown:
jjorgensen52
NHSTE - I'm the only one!
Nope. my trans is from a 305 (1988) F-body, but it's using a bellhousing from a fullsize 75 or so truck so I can fit a 168 under there (it's on them motor right now over my 168 flexplate). Trying to get a lightish flywheel without spending a ton of $$$
tippmann243
jjorgensen52 said:
Nope. my trans is from a 305 (1988) F-body, but it's using a bellhousing from a fullsize 75 or so truck so I can fit a 168 under there. Trying to get a lightish flywheel without spending a ton of $$$
sorry, i got confused i thought you were doing the t56 swap but your doing the t5 swap
Robert Lone
MUTANT
Tippman243,
Are you aware that my truck is a working 6-spd AWD 4.3 Syclone?
I'm not bragging, it just seems like you are not understanding that I have one that works.
No offense,
Robert Lone
Please don't take that the wrong way...
jjorgensen52
Yeah, thats happened a couple times.... T56 is too heavy for the 1 extra gear (it's the same ratio anyway)
tippmann243
Robert Lone said:
Tippman243,
No offense,
Robert Lone
yes im aware.
you have the bolwn/turboed awd truck
you have a custom t case adapet plate welded to the tailhousing of the trans
tippmann243
my t56 is ligher then a 700r4 :dunno:
not sure of the actual weight all i know is i can lift my t56 alone i cant do that with an 700r4
Robert Lone
MUTANT
tippmann243 said:
yes im aware.
Just checkin'... :)
jjorgensen52
It's like 35% heavier than the T-5 ... with the f-body gears it's almost the same anyway.... my OD is .68 to the T56 .62
Robert Lone
MUTANT
jjorgensen52 said:
Haha, I think people are confused. You're trying to hard to jack the thread (because we did about 15 posts ago)
I'm just happy to be "somewhat" involved in a 6-spd conversaition... :rotf:
tippmann243
my 6th gear is .50
only the 93 model year t56's got the .68 6th gear ratio
:rotf: arent we all
jjorgensen52
What, no love for the mutant? I've got my own mutant now, don't worry. And potentially another in the works, but that's under wraps until further notice
jjorgensen52
tippmann243 said:
my 6th gear is .50
:rotf: arent we all
Most I've seen had the .62 OD ... what the heck are you gonna do with a .50 in a truck with 3.42's :lol: ?
tippmann243
swap in 4.56's :tup:
edit
3.42's on a 27" tire pulls 105 mph in 6th at 1950 rpm :lol:
Robert Lone
MUTANT
Yeah, but yours doesn't have a blower hangin' out of the hood... :rotf: :rotf: :rotf:
Sorry for the wicked threadjack Adam...
