So when I went to pick up the Ty from the transmission place they said it had a ton of running issues. This is strange since it's never had an issues since I've owned it.
It will crank and start but run very badly and the check engine light comes on. After running it for awhile it seems to work itself out of the problem. They checked the codes and said it came up with some map sensor codes stored in the computer. I drove it home. It seemed to run ok.
I played around with it at home and it started fine about a dozen times then the last time I tried to start it, it did this start and die thing again. It starts, but dies and if you give it gas to keep it running it blubbers and coughs for a while then it settled down and idled normal.
Any ideas? I've been looking on the forums for related posts, but didn't see any that fit my problem. Thanks for any ideas? Does it need anew map sensor?
