speedpro
Pittman
Could you use a seqential with wideband 02 in a sy ? I know that the sy is a batch fire, but what all would it take to go to a seqential sytem. This way you can correct for individual cyl.
How would I know what cyl is running lean or rich? dont worry got it covered. I have a data logger in the buick I have to do to run it in the sy is get another harness. It would take less that a 2 minutes to move the box from car to truck. (less if you ran)
GEN3Typhoon
If you are using the stand alone.. it will not matter what Fuel injection you run.
If you ask the FAST people.. they will tell you that you are wasting your time.. the benefits do not outweigh the work you will be doing.
This is just what they told me... I called when I bought mine.
You can make the truck any type of FI setup you want.. as far as I know.
You only need the sequential when using 160#ers. Ask Cal Hartline or any other prominent SpeedPro tuner, and they'll say the same. NOT worth the extra effort/money to run sequential. Plus the PTE harness is plug'n'play and is around $1800 for entire setup. I believe a stand-alone harness is $200 + the box is around $2800.
