sytyguy
Moderated User
Had a buddy ride behind me today and report the correct speed from his truck (unmodified 2005 Silverado). My speedo reads as follows (my reading @ correct reading):
55 @ 52
60 @ 55
65 @ 59
70 @ 62
75 @ 65
80 @ 68
Haven't changed anything since 1999 (white face gauges from AutoSyndicate - the kind you had to remove the needle for), but I can't verify if the speedo was off like this then or if it's gotten worse with time. Odd thing is that it seems to get farther off the faster you go past 60 mph (like the weight of the needle is working against a worn out motor). FWIW, I have stock tires wheels and no changes to any of the circuitry or mechanicals (OEM VSS, DRAC, and stock Road Speed Constant value in bin).
When I reset the needle (after the gauge face install), I set the cruise @ 60 mph (verified by scantool) and put the needle on 60. I can understand if I put the needle slightly higher than 60 mph (incorrect VSS reporting, etc....), but why wouldn't the inaccuracy be uniform (off the same amount from 0-120)?
Does this seem like a fixable thing (reset the needle)?
Or should I be shopping for new guts for the speedometer?
TIA
Hood
55 @ 52
60 @ 55
65 @ 59
70 @ 62
75 @ 65
80 @ 68
TIA
Hood
