speedo problems
spoon
ok so i just bought my sy a few months ago and the speedo and odo were not working. I finally crawled under my dash and found the DRAC was not connected. I connected the DRAC and the needle on my speed is reading way off!!!! it reads 20MPH when im going 5MPH and 40MPH and 50MPH when im going 60MPH. does the DRAC need to be recalibrated or is this more serious than that? Thanks
jwaller
Evil Genius/SyTy Guru
Re: speedo problems
drac's are a dime a dozen at the boneyard. replace it and see if it's still screwed up. make sure you get one from a GU6 truck. IE 3.42's. otherwise it will be off.
spoon
Re: speedo problems
I replaced the speed sensor and the DRAC. I have no idea where to go from here. any ideas?
SY2455
70's Veteran
Re: speedo problems
Check your grounds. Mine was showing 20mph setting still. All better now.
spoon
Re: speedo problems
I connected the black wire on the DRAC harness directly to my battery ground and it still does the same thing. but even when the ground is not connected the speedo still sits at like 40mph. but whats even more weird is when I connect and dis connect the ground a couple of times while the truck is running, the needle slowly moves back to zero. ever heard of that?
spoon
Re: speedo problems
Nope, the odometer is stuck at 30,XXX miles and the trip and speedo do not work either. everything else in the instrument panel works just fine just the speedo, odometer, and trip.
spoon
Re: speedo problems
checked the ground next to the thermostat housing and it is secure. Any other ideas??? anyone?
