Speedo is not working
stariy
My speedo stop working, and engine RPM, jumping 400-500 up while driving on freway or street
Heed help
SYTECH
Check the wiring going to your DRAC. Maybe the connection is not tight
The DRAC (white plastic box) is mounted to the outside of your ECM
One of the wires controls the speedo
Good luck
SYTECH
I had my wife drive while I wiggled the wiring harness connector
(Of course the ECM was removed / hanging on the floor for easy access)
I had a bad pin on the DRAC itself. If I held my breath, wiggled my ass, and turned to the left ....just right..... the speedo would come back on
I ended up soldering a jumper from the DRAC pin directly to the wire going to the speedo and the speedo started working again
Good luck
