Xtrempickup
All turbo All the time
i found out the speedo and odometer on this syclone i bought went out about 1000 miles ago. is there odometer and speedo cable driven or speed sensor type. would like to get it back up and working
Check the connections on the DRAC. It's the little plastic box attached to the ECM.Xtrempickup said:i found out the speedo and odometer on this syclone i bought went out about 1000 miles ago. is there odometer and speedo cable driven or speed sensor type. would like to get it back up and working
Xtrempickup said:great i guess that means taking th bottom of the dash off, is it right beneath? can you get at from inside the glove box at all? whats does it look like before i open it up. also is it a speed sensor type set up
