SOLD: ITS 60-1 DBB turbo, 3" DP, ITS mini-gate, dump, High flow cat
DanenGraham
Big in the rear
SOLD
I am selling my RPM (Mike Lee) trubo kit. Please read everything
Asking price $1100 OBO
EDIT: price is without shipping or paypal fees
This kit has about 5-8K miles on it and was purchased new from RPM. This is a bolt on turbo, and clears the A/C, it sould be good to mid 11's.
The hot side has just been ceramic coated black, and it has the polished housing. It is a Dual Ball Bearing, and water cooled midsection. The DP and hot side were purchased with a silver ceramic coating from RPM.
I have never had good boost control with this setup. I dont know why as everyone else that RPM has sold this to has "rock solid boost". Anyway i even shipped the mini-gate back to ITS and had a new one exchanged, and it did the same exact thing. That is why the bottom of the wastegate is not ceramic coated like the DP is. I dont know if the housing needs to be ported, or the wastegate needs to be ported or a new wastegate installed.
ITS 60-1 DBB turbo
RPM 3" DP
ITS mini-gate
SS oil return line
3" dump
3" in/out high flow cat
3" cobra elbow
Radiator elbow to intercooler -- if you want it
I also have the RPM SS water cooler lines for the trubo as well. Brand new, $100 extra. Have to find this as well.
The lower section of the DP the dump and the cat are all still in my truck. I will need to cut them out as its all welded in. If you dont want the the dump or cat, just let me know and i will cut it off right at the start of the dump.
Fins look perfect front and back. It does have the slightest side to side shaft play, but it has had that from when i purchased it. Not sure if there is a way to mesure it, or if it should not move at all. It does not move forward or backward at all.
The pipe on the left has never been used, and would go where i have the dump. The minigate is a dual port, and dont know if it will work or not. It does have a decent amount of rust/build up inside of it, not sure if thats normal or not. I will take a better picture of the valve.
Cobra, and turbo to IC radiator hose.
DP, dump, High flow cat still in the truck.
Re: FS: ITS 60-1 DBB turbo, 3" DP, ITS mini-gate, dump, High flow cat
that a good price.hope you sell it ...
THEMADTYPH00N
The wastegate hole in that housing as is comes from PTE is barely 25mm across as I recall. I think that minigate is 38mm and the tube going to it is 38mm as well. I think opening up that hole in the housing would help a ton. I run a ATR setup which is similar to the RPM and opening that hole on that housing did wonders for my boost control. Hope this helps with the sale.
DanenGraham
Big in the rear
Thanks for the info. I wish i would have gotten it working correctly when the truck was running, so i could have better things to say about it. But it is what it is, it should be a good setup. Might need just a little work.
And i think the wastegate has a 10# spring in it.
DanenGraham
Big in the rear
New price $1000 OBO, plus shipping.
Does anyone want me to split this up??? Open to ideas if i can get both sold
Trubo $600 + shipping
DP wastegate dump high flow cat $400 + shipping
gobabygo
How much for the downpipe shipped to 38824?
I will take the DP wastegate dump high flow cat if you can find a buyer for the turbo.
Also I agree the 1.056" wastegate hole needs to be opened up. I ported mine to 1.20". prior to my porting my turbo (pte61bb) would overboost to 18psi at just half throttle.
blazengmc
hey if u still have that turbo set up please call phil (314)677-7445
DanenGraham
Big in the rear
May have the entire kit sold, with local pickup. Will update as soon as possible.
DanenGraham
Big in the rear
Havent heard back from buyer. Some one say they want the turbo, and i will split this up. Or buy the whole thing.
$950 + shipping for everything
or
$400 + shipping for DP/wg/dump/cat
and
$550 + shipping for turbo
EDIT: Gobabygo and dgoodhue are up first for DP setup if i can get a buyer on the turbo.
