Rinkrat456
Got LS1?
3783lbs with me in the driver seat. Shoot off ideas you guys have for shedding 618lbs without touching the interior except for race seats. Project truck is a 2nd generation 4wd S10 regular cab turned Awd with an all aluminum 5.7L LS1. Crate motor weighed 430lbs complete with wiring harness and short tube headers, which shed about 70-80lbs off the front after the weigh in. 3708lbs now. Passenger gas tank removed and 13 gallon aluminum fuel cell placed in the spare tire location. I figure that's about 100lbs moved rearward and 30lbs total removed. 3678lbs. For the gas tank to be there, the spare tire was ditched, removing 45lbs (full size 235/70R15 and steel rim). 3633lbs. QA1 coilovers, and torsion bars plus crossmember removed, about 65lbs. 3568lbs. Corbeau racing seats swapped out for bucket seats, center console remains. 30-40lbs removed due to the power 8 way adjustable seats. 3533lbs. Tow hooks, skid plates and steel driveshaft replaced with aluminum, maybe 30lbs. 3503lbs. 4x4 tires and aluminum swirlies replaced with 17" and 18" aluminum rims wrapped in Nitto rubber. No change in total weight.
I'm still too heavy! What else can I do? Basic goal is to get this truck deep into the low 12's all motor.
