Sensor question
graham1524
Well-known member
What sensor is on the driver side between injectors 3 and 5 and is there one or two wires going to it?
I was doing a compression check and the sensor was broken and it looks like 2 wires should go to it but theres only one so I'm not sure if its right or not.
Thanks
Re: Sensor question
Thanks
Do you mean the 3 and 5 spark plugs? If so. it's a temp sensor for instrument cluster.
BMFB
Not to scale
Re: Sensor question
Yea, thats the temp sensor for the dash, it only has one prong in it, and a guide pin in the center, should be a grey cap.
