Seating the Torque Converter
Can this be done with the transmission in the vehicle? The transmission has been install doing but after doing more reading I am not confident I did it correctly. The motor has not been started up, so I know the front pump isn't ruined.
myclone
Re: Seating the Torque Converter
As long as you didnt have to tighten the bell housing bolts to get the motor and trans to mate up the tc is seated all the way. Every time Ive goofed and not seated the tc in the pump the tc hits the flex plate well before the trans is flush against the back of the motor.
HTH
George Blake
DONATING MEMBER
It can but your gonna have to have enough room to pull the converter out a little and work it around. That's gonna be a PITA under the truck.
SY2932
Administrator
"Fully seated torque converter. With a straight edge across the front of the bellhousing, the distance to the mounting pads should be approximately 1 inch."
You could lay the "edge" of a straight edge across the bellhousing to check the distance since you won't have much room. Whatever you do, DON'T crush that pump...
cloneman315
make sure u ckeck it because i thought i had mine seated and it wasnt i used the above pic to help me also
gkrcr882
SyTyless......for now!
Don't forget to fill it with fluid before installation. like mentioned, as long as it's not sticking out or sitting flush with the bellhousing, you should be fine:tup:
VermontTy
Support Our Troops
I've had no issue with it several times; slapped it in, gave it a push, bolted up the bellhousing and had to bring the converter back maybe a quarter inch to bolt it to the flexplate.
This is basically what I did, I slapped the used converter back on and bolted the bell housing up. I then had to pull the TC 1/4" to 1/2" to bolt it up to the flywheel. Should I double check it or do you think I am all set? This is on my Corvette that I hope to put FS next week. I remembered reading about stab depth and seating the TC but didn't get around to reading up on it until after everything was installed. My experience with transmissions is with removing auto's (in parts cars) and doing clutches in standards.
Robert Lone
MUTANT
If you had to pull it forward to meet the flexplate, you're in like Flint.:tup:
Rest easy my brother.
EDIT: This one got cleaned up nicely. It was WAY off-topic.
myclone
I think youre ok but then again my advice is worth about as much as the paper its printed on ;) .
George Blake
DONATING MEMBER
I don't mean to hi-jack the thread but any transmissions purchased from me in the future will have the torque converter included. So you purchased a trans, you also have to buy a converter. The converter will be installed on the trans with a brace holding it in place. I just received notification last night of yet another installation error where the converter was NOT seated correctly and the bolts were used to pull the trans up to the engine. This of course damages the pump and/or converter. It's not worth the down time, truck owner aggrivation, and the additional shipping and parts and labor costs incurred. I always tried to give guys their option of getting their own converter because everyone has a favorite converter to use. It's just not worth the problems. Sorry for the intrusion but it seemed appropriate for the thread content.
SY2932
Administrator
That is the bottom line if you opt to do an installation by yourself. If you don't take the time to do it CORRECTLY, that transmission WILL have to come back out and be prepared to pay for it when it does...
FYI My TC was fine. I really was should have double check this stuff before installation. I was frustrated one day because I needed the jack (transmission was sitting on) and jack stand that was under my Corvette for my Syclone. So, I just did it.
