saw blades fittment
i8av8
in order to use my '95 corvette saw blades 17''x8.5" frt. and 17''x9.5" rr on my '92 typhoon will i need spacers(if so, what thickness) or will i need longer studs or will they bolt right on? i know i will have to chop down the front cv axles a bit in order to get the center caps to fit. any help out there?
SYO237
SyTy Registry
Re: saw blades fittment
You will need 1.25" spacers for the rear. The fronts should be fairly flush and look fine just bolting up.
You can find billet alum spacers with the studs already pressed in on ebay for around $50. Of if you wanna go big money, hit up Skulte.
i8av8
thanx for the replies fellow syty-rs. checked ebay and they look really nice.
George Blake
DONATING MEMBER
If you have stock brakes you are fine. If you've done any brake upgrades to the front, the fronts will need a 1/2" spacer. I'm just doing this until I can afford to buy new wheels and tires as I'm sure as hell not taking off the C5 brake setup.
