Re: Saudi Syclone - 2612
Thanks for the kind words guys. I haven't updated in a while because I haven't done much but my Dad has been helping me with a few minor things that are pretty major.
First off, the truck moved home. My Dad was getting hammered with rates for the current unit so he downsized and now rents in a smaller one. It's still a monumental waste of money given the value of the stuff in there but whatever... The implication for me is that there is a lot less space to work on the truck now. Hopefully that will prove a moot point as I qualify in about 5 months and will be moving home and may even have a garage of my own!
The old place...
The new unit looks very similar but is just a lot smaller. I think it's down to 800 sqft from an earlier 1500.
My Dad also adjusted the torsion bars and the truck sits a lot more level though it needs to have the camber done and probably the torsion rods adjusted again.
One of the big changes is the starter motor. Bullydawg helped me get a starter from the US which fits the motor. I tried the ghetto approach and grinding/drilling a stock SyTy starter but it wasn't right. A new starter was cheap so I went for it. Apparently it is much better sounding and I am not concerned about it hitting the flexplate like it did before. I am very pleased with the result.
This then led on to a no-start condition. When I got it running the last time, it was very hard to start and only came to life when my Dad and I cleaned all the plugs. It seemed fine and then stopped running again. I've seen a few similar threads and have wondered what it could be.
Seeing as cleaning the plugs worked last time, my Dad removed them all again to take a look...
I have a few ideas as to why they are so fouled but am open to other suggestions.
The main ones are that the injectors were from two different vehicles; a Syclone with a blown engine and a few years of laying around and a 1999 Chevy Blazer engine. I checked the injectors were the same part number but after all the time between the truck running, they are probably not in the best of shape. My Dad has decided to help me out with some new 60# injectors from TurboTweak for my birthday - pretty awesome of him.
I will put in some new plugs as well.
The wires are all new.
The Code59 is set to a 3 Bar MAP at present so I need to change it to a 2 bar.
I have compression and spark and the timing is good so I hope that those minor changes will fix it and it will run a bit better.
It probably needs a new fuel filter.
I have a new Walbro waiting to go in if it comes to it.
I normally work on my trucks around this time of year but with my final medical exams and all the other stuff going on, (wedding
), it looks like the trucks get to hibernate a bit longer.
I cannot wait to have a job and a place to work on them next year.
Hope you guys are all making your own progress out there! :tup:
