I notice when you lower a 4wd s10 the camber is affected significantly. The top of the wheel is pulled in compared to the bottom. Does the RPM or JS coilover kit correct this issue with their control arms?
Thats when you need to have an alignment done. There are adjustments on the control arm bolts that will help, But only so much, It will depend on how low your going to go.
