jdeangelis
Here's the situation:
*Replaced oil cooler line o-rings. (BTW-If you go to the GM dealer be sure that you get the "reinforced" o-rings detailed on the relacement drawing. A couple of trips back and looking at HIS screen fixed this.) (no problem noticed)
*Changed oil and filter.
*Decided it was a good time to replace plugs.
*All plugs replaced with CR42TS gapped at 0.035". Had to replace one wire. Replaced with an Accell 9000 custom cut.
After all was done I've been having a rough idle. After accelerating/coming to a stop, it;'s ok for about 5 seconds and then the RPMs drop and then pick up again. It seems to settle and then start all over again.
I proceeded to replace one of the vaccuum hoses.(It looked old.) No help.
I pulled all of the spark plugs and rechecked. (Seems ok)
I pulled the two PCV valves just to check. The one closest to the firewall has a lot of vaccuum, the other has no vaccuum(Should it?)
Not sure what to do outside of replacing all of the vaccuum hosing.
Also, my truck has historically "smoked" at startup. It does seem to be smoking a lot more now.
Ideas? I'm kind of at a loss.
