Rough IDLE help?
Silva22
I have a 92 gmc typhoon that has a very rough idle at start up. when i turn it on the idle is very rough and sometimes even turns off as soon as i turn it on. it stays like this for a while until it warms up. but once i put it on drive once again it starts acting up. i dont know what the problem is, i changed plugs, sparks, rotor gave it a tune up and everything and still cant figure it out. Also while driving and i flore it boost goes all the way up but gains speed slowley. Dont know what that could be either. The TY is stock and any advice would help thanks!:(
Osmosis
Re: Rough IDLE help?
Vac leak is what I was thinking.
Spark
Fuel...check fuel pressure at idle and under a load
Air..Vac leak. Get a vacuum gauge and check at ilde. :tup:
berzerker
wookie
plugged cat
fuel pump dying
crossed plug wires
incorrect parts used when tune up was done
just my thoughts
Jimmy
Banned
Big ass vac port on the back of the throttle body needs to be blocked off or it will never idle.
